It would be great to have Bluetooth control of the LEDs
H6160 and H6110
there’s a new api coming very soon
I recently added a Broadlink RM4 Pro IR blaster to Home Assistant. With that setup, I then programmed in the Govee IR remote commands into Home Assistant and thus use the Broadlink RM4 to control my Govee lights (H6138).
What I like about this solution is that the IR blaster opens up the possibility for me to control my dumb TVs, space heater, etc. This one device started to add a lot more possibilities to my HA setup!
Here’s a tutorial to walk through how to setup the Broadlink RM4 Pro.
Where did you find Govee IR codes? I did not know they existed. Do you know if all Govee light devices respond to IR?
More specifically I have Govee’s:
H6199
H6008
H6087
H6054
And I had no clue any of them responded to IR codes. I have the Broadlink RM4 as well as a few Tuya IR Smart Remotes, so I’d love to have those codes.
I have the H613B, and I would also like to be able to control this with Home Assistant.
I found this, but I don’t think this is for Home Assistant:
Does anyone know what this might be for?
Hi, would you mind sharing the captured broadlink remote codes? I have an LED strip with me but don’t have a remote I can use to capture them
