Govee Bluetooth Temperature sensors not pulling temp and humidity
In the past few days my Govee temperature and humidity sensors H5179 are not pulling and updating the temperature and humidity regularly like they always have for the past four years. When I use the Govee app everything seems absolutely fine in the temperature and humidity is updating normally like it should but home assistance not pulling the information. I have two Bluetooth proxies set up on the property and both are registering that they’re working and I can see nodes hitting them and devices that are not pulling our showing their registered through the proxies. Pretty annoying is I have automations that are dependent based off of temperature and humidity
Were the proxies affected by recent changes in ESPHome BLE parameters?
What do the debug logs say?
[Please format any yaml code, compile, run, and error logs ypu post using the forum </> attributes for readability]
