Govee & Eufy
I have began trying to work on using Home Assistant to work throughout my home.
I am having issues getting Govee and Eufy integrated into Home Assistant.
Any assistance would be appreciated,
You might have better luck getting assistance if you describe what issues you are facing. Have you looked in the logs?
Sorry I am VERY novice at this stuff. I cannot see any Eufy products or Govee products to be discovered. I did find some LifX bulbs we have and a television. I am unsure how to use the integration for Govee and Eufy.
Have you tried adding the integrations? Govee lights local - Home Assistant or Govee Bluetooth - Home Assistant EufyHome - Home Assistant
Be more specific, what devices / models are you having trouble with?
In HA, I go to Settings → Devices & Services → click on Govee Lights Local → It shows Needs Attention " 1. Failed setup, will retry: No devices found on the network" I have a couple dozen Govee products. Example Govee Cob Lights Model# H61E6.
It cannot find any of my Eufy Cameras.
I might be in over my head.
I’m not familiar with Govee, but from what I can see here Govee COB LED Strip Light Pro - 1260 LEDs/m | Govee US it seems you connect them with Matter.
I am assuming you tried this on the wifi Govee devices? https://app-h5.govee.com/user-manual/wlan-guide
As for the cameras, are they on the same network as HA or have you segmented? The more info you give the better.
Getting Eufy cameras in HA is a bit of work. You can find more information overhear GitHub - fuatakgun/eufy_security: Home Assistant integration to manage Eufy Security devices as cameras, home base stations, doorbells, motion and contact sensors. · GitHub. It does not come with HA ‘out of the box’.
One note that a new Eufy integration is in the works as Eufy is changing their API’s.
Cheers Rene
