Govee H5054 water sensor
I recently added the Govee H5054 to my arsenal. I’m reding the sensor in with an rtl_sdr and the rtl_433 plug-in. The rtl_433 MQTT auto discovery integration for this sensor sucks but that is besides the point.
How often does this sensor broadcast information?
I would like to keep track of this sensor to make sure it doesn’t go offline. If it does go offline then I will get a notification. So far after the initial install, there don’t seem to be any updates. The two sensors that show up are battery and time. They haven’t updated in over a day. I assume that if using the govee base station the sensor has to check in periodically.
I found these to be silent little creatures. Only sending a message when needed. I got the battery levels when I first installed the batteries and have been waiting 6 months for another. I remember reading somewhere(?) that a battery message is only sent when the sensor detects a change in battery level.
If you want a water detected message, press the test button.
so sorry: i was thinking of the H5040
Thanks, I was afraid of that. So there is no great way to keep track of it other than monitor battery life and hope for the best.
Got my first battery reading just last night. Went from 100% to 95%. More than 6 months.
Please post your HA configuration for these devices. I am considering purchasing some, and would like to know how they connect.
Can you please share your config? I’m trying/failing to integrate these at the moment. See reddit discussion here
and Github ticket here which is attempting to integrate these devices with auto discovery.
Using rtl_433 & MQTT with a SDR dongle. No auto discovery here. Been awhile since I looked at this code but still works.
#Govee Water Leaks
#Location
#  34958 - Utility HW Tank
#  35651 - Utility HW Heat
#  8703  - Kitchen
#  35403 - Bath1
#Events
#  {"time":"2022-01-01 07:48:00","model":"Govee-Water","id":34958,"event":"Water Leak","code":"770a04040744","mic":"PARITY"}
#  {"time":"2022-01-01 07:18:51","model":"Govee-Water","id":34958,"event":"Button Press","code":"770a05050744","mic":"PARITY"}
#  {"time":"2022-01-01 07:24:29","model":"Govee-Water","id":34958,"battery_ok":1.0,"battery_mV":3000,"event":"Battery Report","code":"770a039b034e","mic":"PARITY"}
#  Battery Level ??? Look in MQTT FX for battery level  ???  Maybe only occurs when battery drops  ???
- alias: Alert Msg Red Leaks
  mode: single
  max_exceeded: silent
    - platform: mqtt
      topic: rtl_433/Govee-Water/34958
    - platform: mqtt
      topic: rtl_433/Govee-Water/8703
    - platform: mqtt
      topic: rtl_433/Govee-Water/35403
    - platform: mqtt
      topic: rtl_433/Govee-Water/35651
    - choose:
        - conditions:
            - condition: or
              conditions:
                - condition: template
                  value_template: '{{ trigger.payload != "" and trigger.payload_json.event == "Button Press" }}'
                  value_template: '{{ trigger.payload != "" and trigger.payload_json.event == "Water Leak" }}'
          sequence:
            - service: mqtt.publish
                topic: '{{trigger.topic}}'
                payload: ''
                retain: true
            - condition: state
              entity_id:
                - input_boolean.govee_water_34958
                - input_boolean.govee_water_8703
                - input_boolean.govee_water_35403
                - input_boolean.govee_water_35651
              state: 'off'
              data_template:
                entity_id: 'input_boolean.govee_water_{{ trigger.payload_json.id }}'
            - service: script.alert_control_rotate_notify
                level:   '- RED -'
                message: '{{ trigger.payload_json.event }} {{ trigger.id }}'
                notify:  '{{ trigger.payload_json.event }} {{ trigger.id }}'
                msg:     ''
    - choose:
        - conditions:
              value_template: '{{ trigger.payload != "" and trigger.payload_json.event == "Battery Report" }}'
          sequence:
                payload: ''
                retain: true
                topic: '{{trigger.topic}}/batteryReport'
                payload: '{{trigger.payload}}'
                retain: true
    - choose:
        - conditions:
              value_template: '{{ trigger.payload != "" and trigger.payload_json.event == "Battery Level" }}'
          sequence:
                payload: ''
                retain: true
                topic: '{{trigger.topic}}/batteryLevel'
                retain: true
Here is an MQTT autodiscovery script for these Govee H5054 devices in case it is useful to anyone. This will create a device for each leak sensor containing the binary leak sensor and a few battery and event sensors, all with minimal effort.
This looks really useful. I currently have 11 sensors configured manually, but I’m about to deploy another 8. I’ll try using your script.
Assuming you’re using rtl_433, have you found a way to determine online/offline status? There is no way to configure a birth/death message, and these Govee sensors don’t seem to publish frequently enough to use a timer. Would love to hear what other people are doing.
The device doesn’t broadcast anything on a regular basis so there’s no way to know if it’s still alive other than knowing what the previous battery reading was and how long ago that was received.
I turned on two sensors about 2.5 months ago and they haven’t communicated since then. I think they are supposed to report when their battery changes by 25% so I will see if that happens in the next 6 months.
