I have an automation to turn on a few Govee bulbs at sundown. I see in the log that the automation ran at sundown, but the lights aren’t turned on. When I manually run the automation, it correctly turns on the bulbs. Any ideas on next diagnostic steps?
alias: Deck Path Sunset On
description: ""
- platform: sun
event: sunset
offset: 0
condition: []
- service: light.turn_on
metadata: {}
brightness_pct: 100
entity_id:
- light.path_light_driveway
- light.rgbic_path_lights
- light.deck_string_lights_3
mode: single
Can you post the trace timeline to see if there are any errors, the automation is correct.
I don’t think you yaml is format correctly try just one with ‘entity_id: light.path_light_driveway’
When I try to do an automation with multiple lights, I have to create a separate action for each light.
Unless you put the lights in a group or area.
I tried separating it into three automations (one light in each) - still no luck.
The crazy part is when I manually run the automation, the lights turn on fine. And I can see it’s triggering at sunset.
What happens if you create a new automation with a certain time as trigger and, for starters, 1 of the lights.
If that works, you can add the others 1 by 1, just as a test.
Also, to check if you action - and if used conditions - work, it can help to create a script which you can trigger manually.
That way you can distinguish whether you problem is the trigger or the action (or something else)
Problem solved - I think the Govee API was overloaded with too many calls when they all fired at sunset.
Anyway, I switched to Govee2Mqtt and works fine now.
