GoveeMQTT+Google Home/Assistant- Bluetooth devices Offline
Having a weird issue with the GoveeMQTT and Google Assistant through Nabu Casa. All of my Govee lights that have LAN control show up in Google Home and work fine.
My Issue is that I have two T1 Pros that are Bluetooth only, and show up in MQTT but when I expose the light entity through the voice assistant settings in HA, they always show in Google Home as offline
If I expose the switch entity its shows up online and works in Google Home. Now if turn on/off the switch in Google Home the light entity will briefly show online and then go right back to offline if I try to open it. This happens to both T1 Pros.
Any Idea what could be causing this?
I am having the exact same issue with the T2 but it does have wifi connectivity and still does this exact same behavior. No fix for it yet but looks like I am not the only one.
I thought it might be because there is no lan api switch for the lights in the govee app but I have other lights like that that are working just fine.
