Hi team.
I have been using a Pi Pico to check a reed switch on my garage door.
All working fine until I upgraded my home internet and broke a bunch of configs. I thought I could just download my existing yaml file, flash the Pico with the new secret wifi info and carry on. However when compiling in esphome I now get errors.
code snippit is:
binary_sensor:
- platform: gpio
pin:
number: 16
mode:
input: true
pullup: true
name: "Garage Door Open"
lambda: |-
if (id(garage_door_sensor).state == True) {
// Garage Door is open.
return "Door is open";
} else {
// Garage Door is closed.
return "Door is closed";
The error I now get is:
Compiling .pioenvs/garage-door/src/main.cpp.o
/config/esphome/garage-door.yaml: In lambda function:
/config/esphome/garage-door.yaml:53:40: error: 'True' was not declared in this scope
53 | if (id(garage_door_sensor).state == True) {
/config/esphome/garage-door.yaml:60:3: error: control reaches end of non-void function [-Werror=return-type]
cc1plus: some warnings being treated as errors
*** [.pioenvs/garage-door/src/main.cpp.o] Error 1
========================= [FAILED] Took 25.36 seconds =========================
Was there an update to a format where my “state == True” is no longer valid for the binary sensor?
