Gpio pins intermittently shutting off
I’m going crazy trying to track a problem down. Everything is working but out of the blue I lose the ability to turn on a relay. I change my code in eaphome to a different gpio and it will work for a while and then does it again! The physical momentary switch i have wired up works every time its the switch on home assistant that is intermittently working.
Welcome.
Some esphome logs might help.
I think I actually figured it out. Initially I was only able to manually create projects in esphome and I think I had the wrong boards selected. Now that I can use the gui, it auto discovers the boards. Since having the correct boards selected, it stopped. The learning curve is really steep but I’m absolutely loving esphome now that I’m figuring everything out!
