Hey
Just installed HomeAssistant. So i’m a total beginner.
What i have so far:
The relay board is connected to the Raspberry Pi4 GPIO and i can turn on/off the relays using this configuration.yaml:
switch:
- platform: rpi_gpio
ports:
2: GPIO 2
3: GPIO 3
4: GPIO 4
Manually i can control the dimmer states
- “trigger relay on/off” - turns on the dimmer, when run again it turns it of
- “trigger relay on/wait 500ms/off” dimms to ~50%
- and so on…
Sadly i can’t predict the state of the dimmer.
The questions
Is there a way to lets say “programm” the behavior of the switch, e.g. on setting it to on turn on the relay, leave it on for 500ms to dimm to a certain 50%?
Is it possible to customize the GUI with additional buttons for ON / OFF and a slider (pull left dimms down, and pull right dimms up) ?
SainSmart 16-Channel relay board
Thank you
