GPS device tracker
Hi
I almost got my device tracking worked out but I ran into one last problem. If me or my wife turn off our GPS then the status no longer gets updated so in most cases my wife is always “home” because she turns it off so much. Is there a way to set the gps state to “away” if there hasn’t been any update in X amount of time?
thanks
Hi. Did you figure it out? FWIW, my custom Life360 component has a feature whereby it will generate an event when there hasn’t been an update from a device in the time you configure. It would work perfectly for this. It also has a last_seen attribute that could used as well. Let me know if you’d like more details.
