The OwnTracks documentation writes this:
Home Assistant will use the enter and leave messages to set your zone location. Your location will be set to the center of zone when you enter. Location updates from OwnTracks will be ignored while you are inside a zone.
Is it possible for Home Assistant to show the actual GPS location even if I’m inside the zone?
