Hope I have placed this topic in the right category.
I had the idea to put a tracker on my robotic lawnmower, and have its trace for the past 6 hours shown in home assistant. I am quite new to Home Assistant, but as far as I can tell, this should be possible with the device_tracker platform. Ideally I would like a map on my dashboard, with the trace marked.
Now, the issue I face, is that I cannot find a GPS tracker that connects to Wifi - I have wifi around my house, wo it would be ideal if the gps location could be requested through wifi. Do you know of such a device?
I have only had luck finding GSM devices, but no Wifi.
I went down a quick rabbit hole of looking at triangulation via WiFi…but the best device you can probably get is an old android/iPhone phone maybe. WiFi with gsm/3G fallback and GPS.
Traccar if you use that has an android and iPhone client that can report coordinates.
Wouldn’t a robotic lawn mower report it location anyway or is it Lidar based?
I have it running on a WEMOS D1 mini. FW is Tasmota with GPS enabled .bin. Normally i prefer ESPHome but this works perfectly:
Add in configuration file:
Robo GPS from MQTT
device_tracker:
platform: mqtt_json
devices:
rm1: tele/RM1/GPS
In Tasmota console:
Rule1 ON GPS#lat DO Var1 %value% ENDON ON GPS#lon DO Var2 %value% ENDON ON GPS#vAcc DO Var3 %value% ENDON ON GPS#hAcc DO publish2 tele/%topic%/GPS {“latitude”:%var1%,“longitude”:%var2%,“gps_accuracy”:%value%,“vertical_accuracy”:%var3%} endon;"}
The Tasmota way is much easier as it integrates directly with HA as a device tracking unit so thats why i choosed Tasmota. Beside that i believe that 3 months ago all ESPHome could use the GPS-integration for was to receive time.
Hi, I’m looking to do something similar with my home assistant instance.
I have an Ambrogio robot mower that I cannot interface with, I’d like to track its GPS location.
Have you got any further with your setup? Have you managed to plot a map of where it’s been or any other nice things?
Just wondering what yours looks like now?
And what your final tracking solution was?
