GPS tracking history map
I don’t know if it is possible, but when your using the history component it should store all the locations in the past too. Would be nice if you can create a map where you can see where this person has been the last 24 hours or so. I know you can make the still image maps with google maps, but what about multiple locations over time?
I too would be interested in this. I experimented once with Owntracks and a logger it had but had too many issues. I ended up using GPSLogger. I guess any would work so long as the coordinates are sent back to HA.
agreed would be cool. perhaps though a mod could move this to feature requests?
Well i didn’t put it in future request, because the data is in your database. Perhaps a clever templating thing could already give the same results? I just don’t know how at the moment.
maybe we need a feature request for a clever templating thing :wink:
Seems one can do that themself :slight_smile:
Install the latest version of HA, it now shows history number of hours in the lovelace card!
Oof, 3 years already … time flies
Do I need to enable something to make this happen? I have two devices one tracked by Icloud and one with owntracks but I do not get this visual timeline track like shown on the example
In the default map lovelace card there is a history setting. (this does not work on the general map on the left)
Ah! That works. Thanks
You might want to try this: Home Assistant: Exploring location history - Userbag.co.uk
