Is anybody using this one? Seems it stopped working at some point
I am using it and it works, along with the gpslogger android app…
I have been using it since it came out and it has been the most stable and reliable tracker so far.
I’ve been using it for the past three weeks without issue.
I’ve checked today and it’s still working.
Ok thank you for the info. Guess i’ve made some configuration mistakes than
Do you have a static IP or are you using DDNS ? If DDNS it may be worth checking that it’s updating correctly.
Static. Would you mind posting logging details? Is Log to custom URL the only option on?
And for perfomance
Location providers: Passive
Logging interval: 0
Keep GPS between fixes off
Distance filter 60
Accuracy filter 40
Duration to match accuracy 60
Absolute time to GPS fix 300
Don’t log if i’m not moving off
Just a word of advice re GPSLogger, if you find it isn’t working quite right try increasing the GPS accuracy.
I had it working for a while and then it just looked like it wasn’t working any longer, it was just an accuracy issue.
I guess I did not notice before (nothing setup to trigger with it) but mine has stopped working as well. I have both mine & my wife’s androids setup for it and I know it was working (for many months).
I am getting battery information but not seeing anything on the map.
See my comments above about accuracy, the exact same thing happened to me as I was only seeing battery updates.
I just checked it and it does show me at work right now but I never saw anything on the map while I was out this weekend… odd
