Hi, I’m on 0.8.1 and just setup GPSlogger for my GF Android phone as a device tracker in HA.
It worked great in my LAN until she left the house and got the cell network IP address, I got a bunch of those:
> Login attempt or request with invalid authentication from "her WAN IP address"
URL from gpslogger is sent to a correctly opened port and I use API password for GPSlogger setup in HA configuration.yaml.
Any idea? Same error when she got to her job Wifi network…
I’ve had a similar issue and I’m under the impression that the legacy API auth will eventually be deprecated in favour the new auth system rolled out in parallel a few versions ago. As of 0.80.0 there is a webhooks component - could something like this be used with GPSlogger instead? I’m too much of a newb to set this up myself, but it seems like the right kind of solution.
I would like to know as well the exact format for the URL to setup in GPSLOGGER using the Long Live Access Token (example maybe)
I tried creating a token for it and use it in GPSLogger URL but it doesn’t work…
In HA, I can see the error authenticating:
Login attempt or request with invalid authentication from 192.168.XXX.XXX
I basically tried, at the end of the URL to add:
&Authorization: Bearer ABCDEFGH
or
‘&Authorization: Bearer ABCDEFGH’
***ABCDEFGH being my generated token of course.
Had to change it back to legacy API for it to work for now…
YES! it works using the LLT instead of API password.
After I added it in the header instead and a milion typos later, it finally showed me a successful send.
Thanks a lot
