So most of the resources on this haven’t been updated in a while. All I’m trying to do is pull the state value from a sensor and put it into a markdown card to format the value.
I’m trying to display my blood pressure from Withings in a neater way that looks more representative of how people read blood pressure. Ec. 120/70mmhg.
In my case I have two sensors. sensor.systolic_blood_pressure sensor.diastolic_blood_pressure
I also have a sensor.date_formatted that I’d like to add incase there’s a difference when calling a numeric value rather than a string.
I then receive the following error:
" Visual editor is not supported for this configuration:
The provided value for “content” is not supported by the visual editor. We support (string) but received ({"[object Object]":null}).
You can still edit your config in YAML."
When I’m in developer tools, it pulls the latest number just fine. I’m not sure what I’m doing wrong.
I also tried leaving the >- at the beginning of content but that just results in:
Configuration errors detected:
can not read an implicit mapping pair; a colon is missed (3:79)
1 | …
2 | …
3 | … sensor.withings_systolic_blood_pressure_mmhg }}
This is not my actual sensor ID in case you’re wondering.
@tom_l Thanks so much, that worked! I did have a look at the markdown card Markdown Card - Home Assistant but it didn’t seem to give me quite what I was looking for so thanks.
