Graceful exit from a running script on a given condition?
Is there a graceful way to terminate (exit) from a script before reaching the end, on a given condition?
Can i.e. the service: script.turn_off be used in a script to turn itself off ?
Or is there some kind of exit statement that can be used ?
You can use conditions in the action section of scripts and automations. When it reaches the condition it checks for true and continues. If false the actions terminate at that point.
You could use any of these: https://www.home-assistant.io/docs/scripts#repeat-a-group-of-actions
They all have an exit loop condition option.
Thanks @tom_l for stepping in, but I’m not sure I understand how to make those group actions serve my purpose. All I want is a simple;
If  (so,and so_1)
   Do something_1
elseif (so, and so_2)
   Do something_2
elseif .......
else
   exit
endif
It’s the exit statement (or something similar) that I’m looking for.
Don’t pay attention to the syntax above. It’s just to illustrate my purpose. I know this isn’t proper YAML.
Do while…
Or
Repeat until…
Sorry, you lost me.
I don’t have a condition for Do while… or Repeat until.
What I do is assigning values to variables based on a set of tests (criteria’s), and if none match, then it should exit and not continue without any data. There’s no need to loop or repeat things.
Then finity’s suggestion should work best. Execution of the sequence will stop when a condition resolves to false.
script:
  your_script:
    sequence:
      - service: blah...
      - condition: state
        entity_id: input_boolean.test
        state: 'on' # if the state is 'off' the script stops here.
      - service: blah...
The equivalent in Scripting would be this:
- choose:
   - conditions: "{{ so and so }}"
     sequence:
          ... do something here 1 ...
   - conditions: "{{ this and that }}"
     sequence:
          ... do something here 2 ...
   - conditions: "{{ those and these }}"
     sequence:
          ... do something here 3 ...
If none of the three conditions evaluates to true then the choose is exited (much like the else exit in your pseudo-code example) without doing anything.
Exactly, but then it will continue to the rest of the script.
That’s what I want to avoid.
If none of the conditions are met, it should exit completely from the script.
(Or, one could turn the whole thing around and say that if a specific condition exist, then exit)
You can just leave blank the default action from the Choose Action. If none of the condition is met, it will do nothing.
Just an example-
  - choose:
      - conditions:
          - condition: numeric_state
            entity_id: weather.home
            attribute: temperature
            above: '30'
        sequence:
          - service: light.turn_on
              entity_id: light.your_entity
      - conditions:
            below: '0'
        sequence:
    default: []
Just an example-
Thanks, I will try this and report back :slightly_smiling_face:
A blank default is equivalent to no default statement. If none of the conditions are met it exits choose and continues to process any code beyond the choose (that’s what Viking is trying to avoid).
Only if there is more code beyond the choose statement. All of the script’s logic can be contained within the three conditions of the choose.
If there’s more code beyond the choose, a condition statement can determine if execution should continue (that’s what finity explained).
Long story short, an explicit exit statement simply doesn’t exist in Scripting but its behavior can be duplicated by structuring the execution flow correctly (using the techniques presented).
Thank you so much!!
I must have become a very bad “story teller”. Just see how much it took before I finally found someone who understood my question. I am so happy you stepped in. Now I know that there is no such thing as a simple ‘exit’ statement (or anything similar).
But I do think that there should be one. That, is perhaps something for the feature list :wink:
Correct. An explicit exit statement doesn’t exist because it isn’t needed.
Feel free to request it but don’t expect it to be implemented.
An explicit exit statement is an artifact from a bygone programming era (like a goto statement). As has already been demonstrated, if the execution flow is structured properly it will “exit gracefully” without the use of an exit statement.
you’re welcome… :wink:
Resurfacing this thread as this is what I’m looking for. I have an automation that I want to gracefully terminate, if a message containing some important values is sent to my phone, and I consider risky, allowing the automation to fully execute. Is there any way I can terminate an automation midway its execution?
yes. look at ‘stop’
Is there a reason why you can’t simply use choose or if to either exclude the “risky value” or “deadend” the actions when it is received?
stop is useful if you want to terminate and return a value. To simply terminate, you can also use stop or just structure the logic as I described.
Hey there! thanks for your answer. No, there is no specific reason other than my coding expertise. I will give it a try next weekend and see if I can get away with a choose structure.
Thanks everyone. I will update this thread in a few days.
