note the "%2522"s in the URL - which looks as though it’s trying to escape double quotes twice - which correlates with a “%” at char 13 in the SELECT query.
Bizarrely, Grafana has been fine for months now, and has only just started doing this since I tried logging on just after 5 this evening.
So I’m wondering what’s changed to cause this? I’ve tried restarting HassOS but that did not make any difference.
BTW, I fixed this by going to the “Configuration - Data Sources” section in Grafana, and changing the connection settings to InfluxDB to use POST instead of GET.
Hi all. I just had the same issue and solved in a similar way. I entered the Grafana - Datasource configuration but I had to change the parameter “http method” to “POST”
This was caused by an update of the supervisor, not home assistant. The update will occur automatically, so you rarely see the change notes. Also this was an unintended issue, so not a breaking change.
Version 247 of Supervisor was just released, it should fix the problem. It fixed a similar problem for me with broken URLs (bad percent-encoding) for Grafana and Prometheus (it was also was possible to work around by switching to POST, but now it works with GET).
