Grafana and climate graphs
Dears,
When in the HA history I filter for my climate Nest themostat I can see the following information:
Then, there are 3 temperatures data. I want to show the same information in Graphana, but I can configure the correct query. Graphana only show a similar entity_id but is not the same than climate.salon.
In developers tools I have the following information about my climate.salon:
It seems that Graphana cant find the correct information from this climate integration.
How I can find the 3 data to show the same information?.
Thanks,
I believe it is because you set the measurement to C but your sensor does not have any “unit_of_measurement” defined.
see Customizing Entities on how to add a unit of measure
What database do you have Grafana connected to? And are you sending the climate data there?
I only send sensor data to influx for example.
I datamonkey,
Thanks for your reply, I use Influxdb. I don’t know how customize the climate entity to send to Inluxdb all the data…
I don’t have a climate entity myself, but I would assume it works the same as any other entity:
