Grafana and MySQL Automation Annotations
This is my first post here, thanks a lot to the community and devs for this great, fun, flexible platform.
I would like to share my use of prometheus and grafana to monitor home assistant, this helped me a lot to troubleshoot and ensure my automation rules are working properly and find what rule was triggered in correlation with entities state changes.
I wanted to see what rule caused a state to change without checking the logbook or notify on every rule.
I used mysql data source to query hass mysql db to get the automation rules’ last changed states.
This the the result when annotations are turned on.
Hi, is it possible you give an example of the query you used? I’m new to this and that would give me something to start with!
If someone wants to cut and paste
SELECT
    UNIX_TIMESTAMP(CONVERT_TZ(last_updated, '+00:00', @@session.time_zone)) as time_sec,
    entity_id as title
FROM states
WHERE entity_id like 'automation%'
AND (UNIX_TIMESTAMP(last_updated) > UNIX_TIMESTAMP(last_changed))
ORDER BY last_updated DESC
LIMIT 100;
This started generating an error on more recent Grafana versions.
entity_id alias should be now “text” instead of “title”
SELECT
	entity_id as text
FROM states
LIMIT 100;
Not to high jack this thread but if someone knows how to do annotations with data from influxdb please start another thread with how!!
