Tseven
September 29, 2020, 8:38am
1
Since Grafana version 7.20 (Grafana addon updated 2020-09-23) it is now possible to localize the date format in a env.
read more here about the options
Default is US i.e. MM/DD HH:mm
Update your grafana configuration to DD/MM
plugins: []
env_vars:
- name: GF_DATE_FORMATS_INTERVAL_HOUR
value: 'DD/MM HH:mm'
- name: GF_DATE_FORMATS_INTERVAL_DAY
value: DD/MM
ssl: true
certfile: fullchain.pem
keyfile: privkey.pem
From
To
*Updated typo
Thank you!
I was messing around with that but could not get it to work. I had …INTERVALS _…
Did you try the experimental browser setting?
Tseven
September 29, 2020, 12:50pm
3
Yeah, I tried, thought that would be best but couldn´t get the syntax correct
Settled for now with the fixed setting.
I’m struggling to get this to work at all. I have the following config, but I’m still getting American dates…
plugins: []
env_vars:
- name: GF_DATE_FORMATS_FULL_DATE
value: 'MMM Do, YYYY @ hh:mm:ss a'
- name: GF_DATE_FORMATS_INTERVAL_SECOND
value: 'hh:mm:ss a'
- name: GF_DATE_FORMATS_INTERVAL_MINUTE
value: 'hh:mm a'
value: 'MMM DD hh:mm a'
value: 'DD/MM'
- name: GF_DATE_FORMATS_INTERVAL_MONTH
value: YYYY-MM
- name: GF_DATE_FORMATS_INTERVAL_YEAR
value: YYYY
ssl: false
I have cleared the cache and saving the config restarts the addon. Any thoughts?
Ah, I’m on version 5.2.3 of the addon due to that damned issue with the Supervisor saying my install is unhealthy which I don’t know how to fix. So I can’t update, and that version of the addon is still on Grafana 7.1. So no dice for me right now.
Hi, I’m trying to get my Grafana to use DD/MM date format as described above.
I’m unclear about where this code is entered.
plugins: []
env_vars:
value: DD/MM
ssl: true
I tried to add it to my Configurations file but the configuration check tells me it is not valid:
My Grafana version is v8.1.2
Home Assistant is 2021.10.1
Any tips on how I can make this amendment to the default US date format work?
Thanks!
You add it in the addon configuration page:
Thanks but where is that?
I see no menu like that in Home Assistant.
OK, I think I found it. Will see I go.
OK, now that I’ve found that, when I enter in the code I get an invalid YAML error and of course I can’t save the settings (probably for good reason / just as well).
Any clues on what might be wrong?
I’m unfamiliar with what this code means/does, so I’m just scratching around in the dark.
Remove the square brackets after env_vars. That signifies an empty list when you have nothing in the option.
Thanks! That did the trick.
I now have dates for normal people
No offence to my American friends intended of course.
Tseven
December 14, 2021, 6:29am
13
@anon11644107 to the rescue as always, you are a kind soul.
Regards
Ha! Thanks. I’m not sure everyone here would agree. I have been known to get cranky at times.
Tseven
December 14, 2021, 7:59am
15
Well everyone gets a bit “RTFM-cranky” when answering the same questions over and over. Especially when one have such deep knowledge in HA as you.
At the end of day, I’ve learnt a from the forum heros on here. And you are one of them.
Hats off.
I’m having the same problem as wattmatters in that my Grafana keeps defaulting to American MM/DD rather than British format of DD/MM. I have changed the Configuration YAML to:
env_vars:
value: DD/MM HH:mm
value: DD/MM
plugins: []
ssl: true
Any thoughts anyone?
You are missing an “S” at the end of FORMATS. Should be:
env_vars:
value: DD/MM HH:mm
value: DD/MM
Thanks tom_I
Blimey, isn’t something obvious when it is pointed out! I’ve just corrected it as you advised and it’s worked perfectly. Thank you. It’s appreciated.
maybe someone will find it useful too:
env_vars:
value: DD/MM HH:mm
value: DD/MM
value: DD/MM/YYYY HH:mm:ss
Thanks !
this is exactly what I was looking for
baz123
(Brian)
October 25, 2023, 7:39pm
21
+1 thanks.
But how do you tell Grafana which format to use for a specific panel?
