I’m setting up Grafana and if I’m on my LAN using the internal server DNS http://hassio.local:8123/ I can use Grafana. If using my external DNS via my Reverse Proxy (Sophos UTM) with an Let’s Encrypt Cerificate for my Home Assistant I get only this:
If you’re seeing this Grafana has failed to load its application files
This could be caused by your reverse proxy settings.
If you host grafana under subpath make sure your grafana.ini root_url setting includes subpath
If you have a local dev build make sure you build frontend using: yarn start, yarn start:hot, or yarn build
Sometimes restarting grafana-server can help
External I using home.mydomain.net to open Home Assiatnt and this is my Grafan config:
"plugins": [],
"env_vars": [
"name": "GF_DEFAULT_INSTANCE_NAME",
"value": "Hassio"
"name": "GF_SERVER_DOMAIN",
"value": "home.mydomain.net"
"name": "GF_SERVER_SERVE_FROM_SUB_PATH",
"value": "true"
"log_level": "info",
"ssl": false,
"certfile": "",
"keyfile": ""
Thank’s for any hint because I try days without getting it work.
Steffen
