Good morning all,
Under HA, I have a map with the history of my thermostat as in the image, but I cannot reproduce it under grafana in order to have a better history and a better design. And in passing I would like to add a curve of the outside temperature.
someone to refer me?
hi thereā¦ I guess you have already installed grafana and any database addon like influx db. What is the exact problem you are facing with grafana?
Here is a start, with 3 temperatures pulled from InfluxDB. Still working on converting hvac_action_str to show current_temperature where value is āheatingā, which can then be used to show the green shading.
The three queries are
SELECT mean("current_temperature") FROM "autogen"."state" WHERE ("entity_id" = 'forced_air') AND $timeFilter GROUP BY time($__interval) fill(previous)
SELECT mean("temperature") FROM "autogen"."state" WHERE ("entity_id" = 'forced_air') AND $timeFilter GROUP BY time($__interval) fill(previous)
SELECT mean("value") FROM "autogen"."Ā°C" WHERE ("entity_id" = 'local_temperature') AND $timeFilter GROUP BY time($__interval) fill(null)
Itās getting there, although I cannot figure out how to show the heating periods with area shading.
The query for the heating is as follows. Note the different types of quotes.
SELECT mean("current_temperature") FROM "autogen"."state" WHERE ("entity_id" = 'forced_air') AND "hvac_action_str"='heating' AND $timeFilter GROUP BY time($__interval) fill(none)
Yes influxdb is installed. I donāt have HVAC going back, nor the set temperature I think there must be some handling on HA to do?
how did you get the hvac me i didnāt
I assume that you have installed the InfluxDB add-on in HA and that the log shows a successful launch of the app.
Using the InfluxDB icon in the navigation bar, youāll at first land on the tab for Alerting.
Change to the Explore tab.
Under DB.RetentionPolicy you should see your HA database, e.g. homeassistant.autogen
Clicking on that DB will show all the measurements it contains. Any sensor with a unit of measurement will have its own measurement, everything else and including state attributes can be found under the state measurement.
Scroll down to state or find it via the filter next to Measurements & Tags
Expand state by clicking on the word or triangle
Under entity_id, find your climate entity. Note that this entity_id is shown without the domain. For example, in my case, climate.forced_air becomes just forced_air. You can use the respective filter to more quickly find your entity of interest.
Toggle the entity_id on (blue dot)
Now on the right side you have a long list of Fields. Scroll down to find the field of your interest. In my case Iām looking for the attribute hvac_action, which was copied to InfluxDB as field hvac_action_str
As soon as I toggle on that field, a query appears.
Now you know the search criteria for the query youāll construct in Grafana
Thank you for your explanation, I tried well but I canāt see a result like yours, I get a single curve and I donāt know what it corresponds to
Thanks to the info in this thread I was able to create a very similar graph to the in built HA one but in Grafana.
To do this I had to do the following:
- Follow the instructions above to create the Temperature and Target lines (I created in theGUI)
- Use the following query to create the āHeatingā line
SELECT mean("current_temperature") FROM "state" WHERE ("entity_id" = 'kitchen') AND "hvac_action_str"='heating' AND $timeFilter GROUP BY time($__interval) fill(null)
(I changed mbuscher line from temperature to current_temperature otherwise the fill goes over the temperature)
- Create an override and add the following things:
Fields with Name: NAME OF ALIAS
Graph Style > Connect null values: Threshold (<15m) - This means the gradient wonāt go more than 15min gaps
Graph Styles ) Line Width: 0
If you want a gradient then add
Graph Styles > Fill Opacity: Whatever you like
Graph Styles > Gradient Mode: Opacity
Then you can change the colours of the lines/fill if you want
Let me know if you think there could be any upgrades!
I could as well almost get the same result thanks to this topic. My only problem is the Threshold. My climates can stay without any updates for quite some time.
I will see if adding a keep_alive to my Generic Thermostat will do the trick. But I would be open if anyone come with another solution.
Create a template sensor like this:
unique_id: sensor.heating_graph
state: >
{% if state_attr('climate.heating', 'hvac_action') == 'heating' %}
{{state_attr('climate.heating', 'temperature')}}
{% else %}
0
{% endif %}
And add it in the graph. No threshold needed.
Iām having exactly the same question. However, I updated my InfluxDB to v 2.x and itās only working with Flux. Iām struggeling to transform the query SELECT mean("current_temperature") FROM "state" WHERE ("entity_id" = 'kitchen') AND "hvac_action_str"='heating' AND $timeFilter GROUP BY time($__interval) fill(null)
into Flux to get the same results. Any help would be much appreciated. Thanks.
