TheStigh
(TheStigh)
July 9, 2020, 2:25am
1
Running Grafana add-on, has anybody been able to make the Grafana dashboard with full transparency?
Setting the “Transparent” switch to ON only make the background to be identical to the theme.
Shouldn’t I be able to override the CSS ?
This doesn’t look nice…:
Hey,
Looking to do the same, have you found any solution for this?
tdon
(Tobias)
January 7, 2021, 7:30pm
3
Me too. Would be nice if this is possible!
Gilles_C
(Gilles)
January 24, 2022, 4:57pm
4
Ok, it’s possible but not simple !
You need to active the Boom Theme plugin of Grafana in the HA config :
plugins:
- yesoreyeram-boomtheme-panel
Then you can add in your dahsboard a Boom theme panel, create a theme in it with additionnal CSS style :
body, .panel-container, .dashboard-container, main {
background-color: rgba(0,0,0,0)!important;
Gilles_C
(Gilles)
January 24, 2022, 4:59pm
5
For Chrome/Chromium, you need CSS with your iframe card with card mod :
card_mod:
style: |
iframe {
color-scheme: normal
javempt
(Javempt)
October 24, 2022, 8:20am
6
this didn’t work for me can you pls give me an example of your yaml config for an iframe with a boom theme working? I can get the card to be transparent but as soon as grafana loads it has the background that is set in that panel
This indeed does not seem to work when using in an iframe
