Hello
At first i am using nabu casa.
I have issue with showing iframe graphs form grafana from mobile companion app. It is not showed only for my HA users. In admin account it s work also when i log in to my users account through nabu casa URL on my PC browser it work. It s not showing only in companion app for my users. Could someone help me ?
When i click on grafana on sidebar in user mobile app i get this.
Yes this is very interesting issue. I hope there will be any solution because i try a lot of config without result
I can see the iframes with non admin users. I needed to add a bunch of permissions in the addon’s config tab. I have the following
- name: GF_AUTH_ANONYMOUS_ENABLED
value: "true"
- name: GF_AUTH_ANONYMOUS_ORG_NAME
value: Main Org.
- name: GF_AUTH_ANONYMOUS_ORG_ROLE
value: Admin
- name: GF_SECURITY_ALLOW_EMBEDDING
value: "true"
- name: GF_AUTH_DISABLE_LOGIN_FORM
value: "true"
And your are using nabu casa and companion app ? because your config not work for me
No, I use tailscale.
you are using port for grafana 3000 ? and are you using ingress integration for grafana ?
I use port 3000, I have them in wepage cards.
http://192.168.0.101:3000/api/hassio_ingress/redacted/redacted/building-systems?orgId=1&refresh=1m&panelId=10
my http looks like
http://192.168.1.107:3000/api/hassio_ingress/LC0OteSnmnQXvXXS_Xc-ZehT4-109FzzVklRIYJqBZU/?orgId=1&from=now-6h&to=now&timezone=browser
it is different than yours how you achieve that ?
It’s the same. I’m not too familiar with nabu casa but does that not use https
? Should your address be https
it s work when i log in to nabu casa through PC browser as casual user but when i use companion app its not work
