Grafana Render images librabry missing
Iam using the Grafana Addon in my Home Assistant installation.
Also i have added the plugin: grafana-image-renderer.
When i am trying to render an image link i find the following error in my logs:
Error: Failed to launch chrome!\n/var/lib/grafana/plugins/grafana-image-renderer/chrome-linux/chrome: error while loading shared libraries: libX11-xcb.so.1: cannot open shared object file: No such file or directory\n\n\nTROUBLESHOOTING: https://github.com/GoogleChrome/puppeteer/blob/master/docs/troubleshooting.md\n"
How can i solve this in the ā€œmanagedā€ supervisor addon?
How do you install the plugin grafana-image-rendererā€¦?
Iā€™m trying since 2 days but without success :frowning:
Thanks you !!
Same here, did you made it?
When you look in the documentation of the addon (tab when you have installed the officially addon) you can see how to enable plugins.
Hey out there,
Iā€™m also stuck on that.
using configuration to add ā€˜grafana-image-rendererā€™ does not work for me as it requires an x64 platform.
Is any way to get it done on RasperyPI?
So for Home Assistant on Raspberry Pi (and eventually Home Assistant Yellow) , Grafana will not work with rendered images ? :frowning: Is there any ā€¦ accessible solution ?
