Hi.
I have one sensor that tell me today used energy. How can i make graph contain 30 day (mayble only 15). I want one bar per day. Every bar must cointan this sensor for different day but at 23:59 a clock
This and more would be trivial if you use Influxdb and Grafana, both has plugins for Hassio.
Other option is to create a new sensor from your existing used_energy sensor at midnight with an automation
- alias: record cumulative powergen to midnight
initial_state: 'on'
- platform: time
at: '23:59:00'
service: mqtt.publish
data_template:
topic: home/power/generation/date_prior
retain: true
payload: '{"day_1":"{{states.sensor.energy_generation.state}}"}'
and use the new_sensor along with MiniGraph Card in bar-chart mode to get this:
Limitation of this method is that you can only get graph for number of days the history is kept(By default I guess 12 days).
Hope this helps
