Graph rounding number
I’m using a scrape to return a number from a site, which works well…
But the graph doesn’t want to move from 5.0
Is it defined as a float ?
I have this…
value_template: '{{ value.split("GBX")[1] }}'
try
value_template: '{{ value.split("GBX")[1] | float }}'
Plus add a
unit_of_measurement: '£'
for what ever currency you’re using or it will see it as a discrete value instead of continuous.
Defines the units of measurement of the sensor, if any. This will also influence the graphical presentation in the history visualization as a continuous value. Sensors with missing unit_of_measurement are showing as discrete values.
This just changed the result to zero.
I did this before, didn’t make a difference
The value has a comma in it. Remove the comma
This is how the number is pulled back as it’s a currency.
Yes. But you need to remove it.
value_template: '{{ value.split("GBX")[1] | replace(",", "") | float }}'
Got it, thanks!
