does anyone know how between a graph where on the y axis I have the elevation and on the x I have the azimuth of the sun? Thank you
Can’t be done with stock sensors and Lovelace UI. You would need a UI component capable of plotting arbitrary graphs, while the ones in HA are all for simple time based graphs. Could embed something external using the webpage UI card.
What is the home automation problem you’re trying to solve with this? If you need to do some math on sun angles, that can be done with a template sensor.
