Graph2 - Incorrect Node ID's?
I’m having a few issues with the Graph 2 capabilitiy.
Here is part of the graph
Specifically the node called Aeon Smart Switch (36+)
However, when clicking on it, it shows another node ID - 39 ?
Quesitons:
  1. Why is the Aeon node called 36+ ? Why not just 36 which is it’s real ID
  2. Why does the Aeon node when clicked show a different device, one that isn’t paired with it?
    It seems that when I click on any of the nodes they are all different
    Here is a video of the issue in action - https://www.transfernow.net/ddl/graph
The + indicates Zwave Plus
This was fixed in an updated version in the thread.
Thanks @firstof9
Have upgraded which has fixed the issue with node ID and the representation.
It would appear that finally my garage can communicate with the network through the newly added smart switch (repeater) – Now to test…
It would be great if I could force node 39 to go through 48+ as it’s on the floor and nearby
Keep in mind this is a super basic view of the mesh network. The devices will route as needed for best connectivity to the “hub”.
it probably does anyway. Doesn’t matter what the graph show though, I’ve learned to only treat it as a rough indicator of the mesh health, the comms work no matter what the tree looks like for me :slight_smile:
