Graphical display from Tasmota smart meter
Hi there, I have a problem with the display from Tasmota smart meter. All is looking good, but I want to change the display from Bar to graph. I have a normal Tasmota script
1,77070100010800ff@1000,Gesamt kWh bezogen,kWh,Power_total_in,1
1,77070100020800ff@1000,Gesamt kWh geliefert,kWh,Power_total_out,1
1,77070100100700ff@1,Verbrauch aktuell,W,Power_curr,0
1,77070100240700ff@1,Power L1,W,Power_L1_curr,0
1,77070100380700ff@1,Power L2,W,Power_L2_curr,0
1,770701004C0700ff@1,Power L3,W,Power_L3_curr,0
Which gives me a bar with values
But I want this as a graph, which is more easy to read like this:
How to change this and must it be done in Tasmota or can it be done in HA?
Thanks for helping.
You need to customize your sensor. Edit the customize.yaml and add:
sensor.tasmota_lk13be_power_l1_curr:
  icon: mdi:flash
  device_class: power
  unit_of_measurement: 'W'
sensor.tasmota_lk13be_power_l2_curr:
  icon: mdi:flash
  device_class: power
sensor.tasmota_lk13be_power_l3_curr:
  icon: mdi:flash
  device_class: power
sensor.tasmota_lk13be_amperage_l1_curr:
  icon: mdi:current-ac
  device_class: current
  unit_of_measurement: 'A'
sensor.tasmota_lk13be_amperage_l2_curr:
sensor.tasmota_lk13be_amperage_l3_curr:
Adjust the entity names to your needs
not sure if this is still needed, but will leave it here for others that may search for a solution…
