AdriedeRegt
(Adrie de Regt)
December 16, 2021, 10:00pm
1
I updated my iOS to 15.2 yesterday and now I see that some graphs are distorted in the app. In a browser all seems fine.
Am I the only one that experiences this?
Adrie de Regt
Nabs
December 17, 2021, 2:51pm
2
I see the same, though I don’t know if it started after upgrading to iOS 15.2, or Home Assistant Core 2021.12.2. I did both of them on the same day.
rossk
December 17, 2021, 5:42pm
3
The problem appears to have been reported here:
opened 02:07PM - 02 Dec 21 UTC
bug
safari
### Checklist
- [X] I have updated to the latest available Home Assistant versi… on.
- [X] I have cleared the cache of my browser.
- [X] I have tried a different browser to see if it is related to my browser.
### Describe the issue you are experiencing
In Safari or Safari web-views (e.g. the Home Assistant iOS/macOS companion apps) the `gauge` card doesn't correctly render its dial.
<img width="511" alt="Screenshot 2021-12-02 at 15 00 01" src="https://user-images.githubusercontent.com/170911/144436986-193a5907-e5e0-4c0f-9a73-78dd260ce796.png">
This seems to be due to the way the rotation transformation is applied, via the `transform` SVG attribute [0]:
1. https://github.com/home-assistant/frontend/blob/2a5fc5181e4d1c39588499ac62c4a4fd818508f3/src/components/ha-gauge.ts#L116
2. https://github.com/home-assistant/frontend/blob/2a5fc5181e4d1c39588499ac62c4a4fd818508f3/src/components/ha-gauge.ts#L129
In my test on macOS Safari it seems that the rotation point is not needed anymore (i.e. the transform could be written like: `transform="rotate(<angle>)"`). Furthermore, Safari supports CSS transform rotate, so this could be treated the same like for other browsers.
[0] - https://developer.mozilla.org/en-US/docs/Web/SVG/Attribute/transform
### Describe the behavior you expected
The gauge cards should render correctly, like in all the other browsers (e.g. Firefox, Chrome).
### Steps to reproduce the issue
Have a `gauge` card configured like:
```yaml
- type: gauge
entity: sensor.temperature
min: 0
max: 100
severity:
green: 20
yellow: 22
red: 25
### What version of Home Assistant Core has the issue?
core-2021.11.5
### What was the last working version of Home Assistant Core?
_No response_
### In which browser are you experiencing the issue with?
Safari 15.1
### Which operating system are you using to run this browser?
macOS 12.0, macOS 12.1, iOS 15.1, iOS 15.2
### State of relevant entities
_No response_
### Problem-relevant frontend configuration
_No response_
### Javascript errors shown in your browser console/inspector
_No response_
### Additional information
The card works correctly on iOS 14.8.1.
raf10
(Raf10)
January 4, 2022, 11:02pm
4
I upgraded my Iphone yesterday from IOS 15.1 to 15.2 and have the same issue with the graphs in the App. I tried tried my wife’s phone that is still on 15.1 and it works fine no issues with the graphs.
matbic
January 5, 2022, 11:38pm
5
Same problem for me as well.
