Flexible light and dark modes: You can use it as an automatic theme that adjusts to your system settings, or pick dedicated light or dark modes for full control.
Consistent design: I aim for a polished and professional look across all parts of your home assistant interface.
Custom primary color: You can set a color that matches your style and make it yours.
I use this theme daily on a dedicated wall tablet as well as on Android, Windows, macOS, and iOS devices. To ensure everything works seamlessly across platforms, I regularly maintain the theme and utilize a small abstraction layer to avoid consistency issues across the variants.
The GitHub HA community has already contributed many amazing ideas over the years, and I’d love to hear your thoughts if you check it out!
Maybe it was already suggested,if yes, excuse my ignorance, but I recently purchased a seedstudio Eink display, which I am using to display a “static” home assistant dashboard. Currrently the best fit is Graphite Bright theme, but this also results in lots of dithering. Maybe in the future it would be nice to have a theme that uses the very same color palette as the reTerminal 1002, 1004 uses ?
I am trying to cut the amount of third party mods - HACS, external resources and such to make my setup simpler and more secure. At the same time, I really disliked original HA theme. This one, this one is a godsend! with the help of AI I also managed to use custom font (outfit) for both main theme and sidebar, and now it looks like one of those big tech companies apps. Thank you!
