I used gravatars for pictures in the old known_devices. Is this not possible now after known devices aren´t used anymore after 0.94?
Using “gravatar: email” in customize.yaml does not work.
Same question here. Someone have a solution?
I have the same question. Have tried adding to customize.yaml, and “name: <custom name>” works, but as indicated, I confirm that it doesn’t take any notice of gravatar: <e-mail>. This means that an icon consisting only of an intial letter shows up in the map display, and a generic person icon shows up for an device entity in a glance card in Lovelace.
Following this thread I success to get it working:
And especially this part:
and I just have found out that using
entity_picture
and full path (link) to gravatar works
I have for the moment not access to my config but tell me if you do not success I will give you more details.
Assuming that your known_devices.yaml
file is still in place you can find the full path to the gravatar path using your GUI. Navigate to Configuration - Customization and find the entity which was referenced in know_devices.yaml
as the device tracker. Then locate entity_picture(JSON formated)
which shows full path to gravatar.
This works! thanks
customize.yaml
entity_picture: http://gravatar.com/avatar/md5 hash (encoded value of email adress)
This also worked for me. Many thanks.
