I made a Automation that should turn on and off a smart switch at a given temperature and between a given time. Time and Temp are set in an input.datetime and input.number.
alias: "Smart Switch - Radiator Badkamer Power On/Off at Target Temperature"
description: >-
Zet de Radiator Badkamer Aan of Uit als de Temperatuur op de Badkamer voor 1 minuut Boven of Onder de Target Temperatuur komt
en de optie Power On/Off at Target Temperatuur Aan staat.
value_template: >-
{{ states('sensor.time') ==
(state_attr('input_datetime.smart_switch_radiator_badkamer_power_on_time',
'timestamp')| int | timestamp_custom('%H:%M', False) ) }}
- platform: state
entity_id:
input_boolean.smart_switch_radiator_badkamer_power_on_off_at_target_temperature
to: "on"
for:
hours: 0
minutes: 0
seconds: 10
- platform: state
entity_id:
- sensor.target_temperature_badkamer_state
to: "Temperature Below Target"
for:
hours: 0
minutes: 1
seconds: 0
- platform: state
entity_id:
to: "Temperature Above Target"
for:
hours: 0
minutes: 1
seconds: 0
- choose:
- conditions:
- condition: and
conditions:
- condition: trigger
id:
- start_time_target_temperature
- condition: state
entity_id: >-
state: "on"
for:
hours: 0
minutes: 0
seconds: 5
sequence:
- choose:
- conditions:
- condition: and
conditions:
- condition: state
entity_id: sensor.target_temperature_badkamer_state
state: "Temperature Below Target"
- condition: state
entity_id: switch.smart_switch_radiator_badkamer
state: "off"
sequence:
- type: turn_on
device_id: 9fd68ababf5bcd3c9ffcb1dfc76bd117
entity_id: f9ddeaf40cab46eee52b983474b4b9c7
domain: switch
- conditions:
- condition: and
conditions:
- condition: state
state: "Temperature Above Target"
- condition: state
state: "on"
sequence:
- type: turn_off
domain: switch
- conditions:
- condition: state
state: "Temperature On Target"
sequence:
- stop: "No action needed."
response_variable: "No Action Needed"
- conditions:
- condition: and
conditions:
id:
- enable_target_temperature
- condition: state
entity_id: >-
state: "on"
for:
hours: 0
minutes: 0
seconds: 5
- condition: template
value_template: >-
{{ states('sensor.time') >=
value_template: >-
{{ states('sensor.time') <=
(state_attr('input_datetime.smart_switch_radiator_badkamer_power_off_time',
sequence:
- choose:
- conditions:
- condition: and
conditions:
- condition: state
- condition: state
state: "off"
sequence:
- type: turn_on
domain: switch
- conditions:
- condition: and
conditions:
- condition: state
- condition: state
state: "on"
sequence:
- type: turn_off
domain: switch
- conditions:
- condition: state
sequence:
- conditions:
- condition: and
conditions:
id:
- low_temperature
- condition: state
entity_id: >-
state: "on"
for:
hours: 0
minutes: 0
seconds: 5
value_template: >-
value_template: >-
- condition: state
state: "off"
for:
hours: 0
minutes: 0
seconds: 5
sequence:
- type: turn_on
domain: switch
- conditions:
- condition: and
conditions:
id:
- high_temperature
- condition: state
entity_id: >-
state: "on"
for:
hours: 0
minutes: 0
seconds: 5
value_template: >-
value_template: >-
- condition: state
state: "on"
for:
hours: 0
minutes: 0
seconds: 5
sequence:
- type: turn_off
domain: switch
mode: single
It’s a big one haha. But in daytime it is working, but in Night time it is not because the template:
value_template: >-
value_template: >-
time ON is greater than 23.00(night) and time OFF is smaller than 8.00 (morning)
And that is not possible, because greater than 23.00 cant be smaller than 8.00.
Is there any other way to use a datetime.number ot template in an automation with time?
Also if someone has an idea of making this automation smaller, your welcome
