Gree Climate integration for multi AC is missing entities for other devices
I have Gree Pular in multi-split configuration (two internal devices). Both were added to the Gree+ app and both are found with the Gree Climate integration. But only one has entities and it’s always the first on the list - I tried to add them few times and it was randomly shown one of two as a first found. The second always doesn’t have any entities. Am I doing something wrong? Should I set something somewhere? Or is a bug of sort?
Ok…I found what the issue was. At least I think it was directly related to that: HA/Gree integration wanted to create entities for both devices with the same names. I discovered that when I tried to set friendly name to both devices along with renaming entities. I started with one that didn’t have entities and after this change they showed up.
