Hello, I have a problem with Gree air conditioners a year and a half ago, when I bought them, I integrated them very easily in HA, although after I reinstalled the system and wanted to integrate them, it seems that the integration no longer works it tells me that they are not found on the network… on the network I can see them from the application, they work the same way… I can’t possibly make the correct settings through hacks, can someone give me exactly all the steps and how they should look in the config .ymal and so on. Thanks in advance!
There’s a HACS custom module I’m using, because of the same reason. This information may not be much of use a year later, I realize, sorry
