GREE Integration - Devices disconnecting quirk
First and foremost, please excuse the wrong category, I just wanted to share my discovery on GREE devices that keep disconnecting from WiFi for seemingly no reason.
I have an “Argo Milo Plus” portable AC unit that has been working flawlessly with HA for a long time now (a few weeks). Today, I noticed it kept disconnecting from my home network, with no clear explanation for why. I have set it up to connect to my network with the GREE application on my Android device.
It turns out, these devices do not like being run “offline”, as in without a connection to the world, if connected to the network through an application. I have not tested the app-less configuration yet (which involves connecting to it’s hotspot and sending some packets) with respect to this behaviour.
The device will attempt to send ICMP requests to the gateway indicated by the DHCP Reply, and if these fail for whatever reason (in my particular instance, I disabled ICMP requests to my router, they were being dropped), it will disconnect from the network.
I have not seen this documented yet, and I thought about sharing this quirk with the world.
Can you explain how you set that up?
Thanks for the info, noticed the same for me
That’s why You should use a dummy server > GitHub - emtek-at/GreeAC-DummyServer: Dummy Server to which Gree ACs can connect.
This is exactly whats happening with mine. I thought it was a compatibility issue with the wifi 6 router and changed it but it still happens. I tried enabling the ICMP to my router but I now use a DMZ to my linksys mesh routers and the problem persists, even on the gree app.
I will now try creating the dummy server and see if this works. It is very annoying that this is happening even when you pay extra to have wi-fi connectivity.
im using dummy server for years and it solves every connection problems. hvacs just works and doesn’t drop connection. good luck! :slight_smile:
