Hi All,
My Gree Climate integration throw error every 5 minutes:
homeassistant | 2021-12-01 16:00:47 ERROR (MainThread) [homeassistant] Error doing job: Fatal write error on datagram transport
homeassistant | Traceback (most recent call last):
homeassistant | File "/usr/local/lib/python3.9/asyncio/selector_events.py", line 1056, in sendto
homeassistant | self._sock.sendto(data, addr)
homeassistant | TypeError: str, bytes or bytearray expected, not NoneType
homeassistant | 2021-12-01 16:00:47 ERROR (MainThread) [greeclimate.network] Connection was closed unexpectedly
homeassistant | 2021-12-01 16:05:47 ERROR (MainThread) [homeassistant] Error doing job: Fatal write error on datagram transport
homeassistant | 2021-12-01 16:05:47 ERROR (MainThread) [greeclimate.network] Connection was closed unexpectedly
Home Assistant version:
System Health
version: core-2021.11.5
installation_type: Home Assistant Container
dev: false
hassio: false
docker: true
user: root
virtualenv: false
python_version: 3.9.7
os_name: Linux
os_version: 5.10.0-9-amd64
arch: x86_64
timezone: Europe/Budapest
GitHub API: ok
Github API Calls Remaining: 4998
Installed Version: 1.18.0
Stage: running
Available Repositories: 975
Installed Repositories: 3
logged_in: false
can_reach_cert_server: ok
can_reach_cloud_auth: ok
can_reach_cloud: ok
dashboards: 2
resources: 1
mode: storage
Docker Compose file:
version: '3'
services:
homeassistant:
container_name: homeassistant
image: "ghcr.io/home-assistant/home-assistant:2021.11.5"
volumes:
- /opt/home-assistant/config:/config
- /etc/localtime:/etc/localtime:ro
restart: unless-stopped
privileged: true
network_mode: host
Can somebody please help me figure out the problem?
Thanks!
