Green-to-red icon color gradient template (battery percentage)
In the past I have added templates to set the color of an icon based on a battery percentage. While this works, in this example, it is only limited to three colors.
variables:
  var_color: |-
    var battery_level=entity.state;
    if (battery_level > 70) return 'lime';
    else if (battery_level >= 30) return 'yellow';
    else return 'red';
Obviously, it would not be hard to scale to add more colors. I’ve seen examples posted here in the forum that include as many as a dozen variables. But I wanted to make something better.
A while back I came across a Javascript snippet that converted a percentage to a HEX value for color ranging from red-to-green. (Javascript color scale from 0% to 100%, rendering it from red to yellow to green · GitHub) I wanted to incorporate something like it but didn’t know what I was doing or have the time.
So, here is what I adapted and applied the template to a custom:button-card and Mushroom Template Card:
custom:button-card
type: custom:button-card
entity: sensor.s22_ultra_battery_level
show_state: true
variables:
  var_color: |-
      var percentage = entity.state;
      var r = 0; var g = 0; var b = 0;
      if (percentage < 50 ) {
        var r = 255;
        var g = parseInt(5.1 * percentage);
      } else {
        var g = 255;
        var r = parseInt(510 - 5.10 * percentage);
      var h = r * 0x10000 + g * 0x100 + b * 0x1;
      return '#' + ('000000' + h.toString(16)).slice(-6);
styles:
  icon:
    - color: '[[[ return variables.var_color ]]]'
Mushroom Template Card (I had to change the formula a little bit in this example. I believe the numbers were being rounded differently than the Javascript example and caused numbers greater than 96% to calculate incorrectly. I also customized the icon in this example. The custom:button-card inherits its icon from the entity but the Mushroom Template Card does not. The icon will show the appropriate icon for percentage and charging indicators.)
type: custom:mushroom-template-card
primary: '{{ state_attr(entity, "friendly_name").title() }}'
secondary: '{{ states(entity) + "%" }}'
layout: vertical
icon: |
  {% set battery_level = states(entity) | int // 10 * 10 %}
  {% set charging_state = states('sensor.s22_ultra_charger_type') %}
  {% set is_charging = is_state('binary_sensor.s22_ultra_is_charging', 'on') | iif(True, False) %}
  {% set map = {"none":"", "ac":"charging-", "wireless":"charging-wireless-"} %}
  {% set charging = map[states('sensor.s22_ultra_charger_type')] %}
  {% if battery_level == 100 and is_charging == True %} mdi:battery-charging
  {% elif battery_level == 100 %} mdi:battery
  {% elif battery_level >= 10 %} mdi:battery-{{charging}}{{battery_level}}
  {% elif battery_level >= 0 %} mdi:battery-{{charging}}outline
  {% else %} mdi:battery-unknown
  {% endif %}
icon_color: |-
  {% set percentage = states(entity) | int %}
  {% set r, g, b = 0, 0, 0 %}
  {% if (percentage <= 51) %}
    {% set r = 255 %}
    {% set g = (5.0 * percentage) | round | int %}
  {% else %}
    {% set g = 255 %}
    {% set r = (505 - 4.89 * percentage) | round | int %}
  {% endif %}
  {{ "#%0x" | format( r * 0x10000 + g * 0x100 + b * 0x1 ) }}
Source:
// License: MIT - https://opensource.org/licenses/MIT
// Author: Michele Locati <[email protected]>
// Source: https://gist.github.com/mlocati/7210513
function perc2color(perc) {
	var r, g, b = 0;
	if(perc < 50) {
		r = 255;
		g = Math.round(5.1 * perc);
	else {
		g = 255;
		r = Math.round(510 - 5.10 * perc);
That is really nice and might by useable elsewhere to.
Personally, I find those gradients to be used optimally when actually showing that scale completely and not on an individual icon ( like the battery now). The scale shows it’s power (the actual full gradient) while a single icon only holds, well, a single color :wink:
Couldn’t t we try and show this on let’s say the background scale of the gauge card?
Thomas posted something like that but I’ve never been able to get that working.
This might be another way to do so .
Have to look up the other post
Found it Gauge Card: how to get a gradually changing color? - #12 by thomasloven
Nice work! I just successfully added your code to a card_mod: tweak to style the battery icons as secondary entities in a custom:multiple-entity-row card which doesn’t support icon_color:
decluttering_templates:
  iblinds:
    card:
      type: vertical-stack
      cards:
        - type: custom:mushroom-title-card
          title: ''
          subtitle: '[[display_name]]'
          alignment: center
        - type: entities
          entities:
            - entity: cover.[[blind]]
              type: custom:multiple-entity-row
              show_state: false
              card_mod:
                style:
                  hui-generic-entity-row$state-badge:
                      ha-state-icon {
                        {% if is_state(config.entity, 'open') %}
                          --card-mod-icon-color: green;
                          --card-mod-icon: phu:blind-tilt-open;
                        {% else %}
                          --card-mod-icon-color: orange;
                          --card-mod-icon: phu:blind-tilt-closed
                        {% endif %}
                  hui-generic-entity-row>div>div:nth-child(2)>div>state-badge:
                      ha-state-icon {
                          {% set percentage = states('sensor.[[blind]]_battery_level')|int %}
                            {% set r = 255 %}
                          {% else %}
                            {% set g = 255 %}
                          {% endif %}
              entities:
                - entity: sensor.[[blind]]_battery_level
                  unit: ' '
                  icon: true
          show_header_toggle: false
          state_color: false
          card_mod:
Armed with the above information, I have just successfully added an icon_color: template using custom-ui-only and my battery icons are now colored everwhere, including more info!
configuration.yaml:
home_assistant:
  customize_glob:
    sensor.*_battery:
      templates: &battery_color
        icon_color: >
            var r = Math.min(255, Math.round(510 - 5.10 * Number(state)));
            var g = Math.min(255, Math.round(5.10 * Number(state)));
            var h = r * 0x10000 + g * 0x100;
#          return 'rgb(' + r + ',' + g + ',0)';
    sensor.*_battery_level:
      templates: *battery_color
Very nice…. Would be good it applies to all battery icons… even mushroom chipcards.
good day i tried to implement your custom:button-card and it is ok, but i cannot manage to resize it to fit my other 1row 2column button. any suggestion about that?
@Porzioev If assuming you’re using the Sections View. The custom:button-card has not been updated since February and Sections View was added a few months after that. There’s an open issue requesting support for Sections and the Dev commented on it back in July…
Take a look at Section Support · Issue #854 · custom-cards/button-card · GitHub. There seems to be a couple of workarounds in there. I don’t use Sections View myself, so I don’t know what would be useful or not.
