I’m about to get started with home automation. First goal is the central heating system. It is a hydronic system, wall mounted radiators in every room and a gas boiler.
If you were starting from scratch today and wanted to buy the products that are easiest to use with Home Assistant and other free software solutions:
which TRV would you buy for the radiators, in particular, for compatibility with the software and for compatibility with the valve bodies?
which other products and brands would you choose, for example, temperature sensors, occupancy sensors, managed power outlets?
which network protocol would you prefer, or does it matter?
any other comments?
