To activate weather adjustments check the description of the Github repo and the Wiki of sprinklers_pi
guys -first thanks a-reda for the detailed description! Does someone have figured it out for the gen3? Or how can you include the wifi infomration on the freshly installed rpi?
Peter
Thanks a-reda, its ready, now run with DarSky. When i have time i seeing for Netatmo.
Please, let me know if you configure Netatmo as your PWS…
I think Weather underground is no longer accesible with the api key…
so no solution for gen 3
I think, no solution at this time! I send my controlller to resseller for garanty.
Hello ANM
Did you bring the sprinkler pi Version up and running on gen3?
And also did someone solve the issue of what username to use on gen 3 direct http login?
Thanks Peter
At the momemt I am working on a gen2 model, hopefully next week on gen3
Hello
Anyone can help on the login issue for the 3 gen direct connection?
Peter
I have been able to make my Gen2 working by correcting current software issues:
Actually, latest upgrade was intented for Gen3 and caused issues for the Gen2: the scheduler did not work properly on Gen2 with all the zones defined for Gen3. Time management was clearly not made to work without the cloud
Right now, it lacks taking account timezone to have a fully working GreenIQ direct software.
If I can have access to a Gen3, I might. But it is likely that the password is hashed on it so it can not be retrieved. If this is true, that would leave three options:
- change the hash directly on the SD card,
- make it update by mocking up GreenIQ cloud to have a new known password,
- check if Sprinkler PI work on a Gen3 - I guess it is possible since I am expecting the Gen3 to run a Debian
Can you give a try with information provided here? The Gen3 is based on a Arietta G25
Arietta G25 - Linux embedded system on module (downloads tab)
I expect them to have changed default password, but still, maybe the Web access is still available
hello, no unfortunately the username / logins are not working. They always refer to a plastic card to find username and password, but I never received that with the original product.
best peter
Hi, I have a Gen3. It continues to connect to my wifi network.
Once I get my local IP, I can access it with chrome.
I tried to connect by ssh. Port is activated.
But root/acmesystems doesn’t work
ssh [email protected]
[email protected]’s password:
Permission denied, please try again.
The clock is not syncrhonised (in the status menu) and when I click Sync Device Watch, it does nothing…
The files on the SdCard are :
-Some hidden directory of previous binaries (probably before upgrade)
- zImage file
- boot.bin file
- acme-arietta.dtb
These files are from summer 2017.
Any idea about the root password ?
hello,
and if you connect through webbrowser chrome - which I also use - it does not ask for any username or password?
best p
no, it does not ask for a username or password.
No, I don’t. I should add that ssh is desactivated after 15 minutes of what GreenIQ considers of no Internet connection (it means no cloud).
taaazh, this files should be from the first partition, a second one should be present (but not readable under Windows)
The Sync Device Watch function is messy. The Sync Device Watch writes your computer’s time on the GreenIQ with your timezone, which is wrong.
In short: the time management is not consistent, some times does not take into account the timezone while some does (since there is no longer a cloud). So there are offsets and when you schedule something, there are several hours of difference (depending of your timezone)
Message edited:
- I forced clock sync at boot from NTP (UTC based)
- only the Sync Device Watch function needed to be corrected:
- displays time with local timezone
- sends time without to the GreenIQ
With clock sync at boot, the Sync Device Watch is no longer useful.
Now, everything works fine, from manual irrigation to planned ones (time zone is added on the display):
By the way, the GrenIQ was connecting to a secured MQTT server (part of the GreenIQ cloud). I changed it to a local MQTT server but the topics are limited:
- topic “/hub/sn/status” : the GreenIQ unit pushes its status (online or offline)
- topics “/hub/sn/config” , “/hub/sn/sensors” and“/hub/sn/fertilizer” : the GreenIQ unit is listening those topics, any message received, whatever the content, forces an update requested to the cloud.
I guess IFFT integration was performed like this :
- any request was sent to GreenIQ cloud that updated their configuration,
- a message was sent by MQTT to request an immediate update of the GreenIQ unit,
- once this message was received, the GreenIQ unit was requesting the config.xml file from GreenIQ cloud (it allowed to be quicker that the ‘one-minute’ loop)
can you try with password: pass
or acme?
I do not have a Gen3 so I can not try.
Hello I can try tonight. Any way to initiate a hard reset? I don’t really understand why some 3 gen products have the username password and others not…
