Grid card looks great on wall panel, terrible on phone
I was having trouble getting proper wrap of two cards on a dashboard tab, so I solved it with a two grid setup on the HACs custom grid card.
On my Kindle Fire wall panel in landscape mode it looks fantastic, but on my phone which is vertical everything is messed up and skinny.
Is there a solution, should I be doing a different dashboard tab depending on which user is looking at it and having some tabs only available to my kiosk user, and some hidden from my kiosk user? How will that affect swiping?
I have one whole dashboard designed for desktop and one for small screened mobile devices. You can assign the default dashboard on each device.
Same here. The only good solution to have the layout set right on any screen format.
Sounds like a great idea, and copying dashboards is pretty simple. Question. Why do it with different dashboards, rather than one global dashboard with custom tabs that are visible or invisible depending on the user? Having a unique user for the wall-mount tablet makes that easy. Pluses and minuses?
I don’t want my family members to have two different logins depending on the device they use. WAF unfriendly…
This way, everyone has one set of login credentials and per device they set the preferred dashboard. But still can switch to the other, if needed.
I sometimes use a vertical layout-card (with a max number of columns) and insert breaks manually where I think it would wrap great on the phone, and sometimes I use a single column horizontal layout-card with “groups” within, consisting of either vertical or horizontal layout cards that themselves contain the cards I want to arrange. The goal is for wide screen dashboards to look nice single-column, and it’s hard to think about how to arrange the cards for this, but so far I’ve gotten away with it.
This one is a masonry layout that adapts:
The trick is that the inner tiles are themselves vertical stacks, so whatever I want to stick together vertically, I will add to a vertical stack inside my layout. You can totally do the same with the grid, by the way!
Some sample code for the screenshots (incomplete):
  - theme: Backend-selected
    title: Appliances
    path: appliances
    icon: mdi:vacuum
    badges: []
    cards:
      - type: vertical-stack
        cards:
          - type: custom:mod-card
            card:
              type: custom:mushroom-title-card
              title: Cleaning
              alignment: start
            card_mod:
              style:
                mushroom-title-card$: |
                  div.header {
                    padding-bottom: 0;
                  h1 {
                    font-size: 125% !important;
          - type: grid
            columns: 2
            square: false
            cards:
              - type: custom:mushroom-entity-card
                entity: vacuum.sucker
                entity: sensor.sucker_status
                entity: sensor.last_vacuum_cleaned_area
                entity: sensor.sucker_battery
                icon: '{{ state_attr("vacuum.sucker", "battery_icon") }}'
                icon_color: |-
                  {% set level = states('sensor.sucker_battery') | int %}
                  {% if level >= 30 %}
                  green
                  {% elif level >= 15 %}
                  yellow
                  {% else %}
                  red
                  {% endif %}
                primary: Battery level
                secondary: '{{ states(''sensor.sucker_battery'', with_unit=True) }}'
                entity: sensor.last_time_sucker_finished_cleaning_seconds
                entity: input_datetime.next_vacuum_time
                tap_action:
                  action: more-info
          - type: custom:tabbed-card
            tabs:
              - attributes:
                  label: Full
                card:
                  type: custom:xiaomi-vacuum-map-card
                  vacuum_platform: Neato
                  map_source:
                    camera: camera.sucker_cleaning_map
                  calibration_source:
                    identity: true
                  map_locked: true
                  tiles: []
                  icons:
                    - icon: mdi:play
                      conditions:
                        - entity: vacuum.sucker
                          value_not: cleaning
                          value_not: error
                          value_not: returning
                      tooltip: Start
                      tap_action:
                        action: call-service
                        service: vacuum.start
                        service_data:
                          entity_id: vacuum.sucker
                    - icon: mdi:pause
                      conditions:
                          value_not: docked
                          value_not: idle
                          value_not: error
                          value_not: paused
                      tooltip: Pause
                      tap_action:
                        service: vacuum.pause
                        service_data:
                    - icon: mdi:stop
                      conditions:
                          value_not: docked
                          value_not: idle
                          value_not: error
                          value_not: paused
                      tooltip: Stop
                      tap_action:
                        service: vacuum.stop
                        service_data:
                    - icon: mdi:home-map-marker
                      conditions:
                          value_not: docked
                      tooltip: Return to base
                      tap_action:
                        service: vacuum.return_to_base
                        service_data:
                    - icon: mdi:target-variant
                      conditions:
                          value_not: docked
                          value_not: error
                          value_not: cleaning
                      tooltip: Clean spot
                      tap_action:
                        service: vacuum.clean_spot
                        service_data:
                    - icon: mdi:map-marker
                      tooltip: Locate
                      tap_action:
                        service: vacuum.locate
                        service_data:
                  map_modes: []
              - attributes:
                  label: By area
                card:
                  map_locked: true
                  map_source:
                    camera: camera.neato_floor_plan
                    crop:
                      top: 90
                      bottom: 120
                      left: 65
                      right: 105
                  calibration_source:
                    identity: true
                  tiles: []
                  icons: []
                  map_modes:
                    - template: vacuum_clean_segment
                      predefined_selections:
                        - id: Kitchen
                          outline:
                            - - 340
                              - 610
                            - - 670
                              - 610
                            - - 670
                              - 700
                            - - 460
                              - 700
                            - - 460
                              - 800
                            - - 260
                              - 800
                          icon:
                            x: 490
                            'y': 710
                        - id: Office
                          outline:
                            - - 240
                              - 850
                            - - 670
                              - 850
                            - - 670
                              - 1005
                            - - 170
                              - 1005
                          icon:
                            x: 450
                            'y': 930
                        - id: Living space
                          outline:
                            - - 670
                              - 250
                            - - 950
                              - 250
                            - - 950
                              - 1080
                            - - 670
                              - 1110
                          icon:
                            x: 810
                            'y': 680
                        - id: Gym
                          outline:
                            - - 1020
                              - 250
                            - - 1270
                              - 250
                            - - 1270
                              - 520
                            - - 1020
                              - 520
                          icon:
                            x: 1140
                            'y': 380
                        - id: Guest bathroom
                          outline:
                            - - 950
                              - 650
                            - - 1110
                              - 650
                            - - 1110
                              - 780
                            - - 950
                              - 780
                          icon:
                            x: 1030
                            'y': 715
                        - id: Master bathroom
                          outline:
                            - - 1130
                              - 540
                            - - 1250
                              - 540
                            - - 1250
                              - 780
                            - - 1130
                              - 780
                          icon:
                            x: 1190
                            'y': 660
                        - id: Master bedroom
                          outline:
                            - - 950
                              - 835
                            - - 1160
                              - 835
                            - - 1160
                              - 780
                            - - 1260
                              - 780
                            - - 1260
                              - 835
                            - - 1260
                              - 1050
                            - - 950
                              - 1080
                          icon:
                            x: 1130
                            'y': 960
                      max_selections: 1
                      service_call_schema:
                        service: neato.custom_cleaning
                        service_data:
                          entity_id: '[[entity_id]]'
                          zone: '[[selection_unwrapped]]'
      - type: conditional
        conditions:
          - entity: climate.novamatic_cl_1590
            state_not: unavailable
        card:
          cards:
              card:
                title: Air conditioning
                alignment: start
              card_mod:
                style:
                    div.header {
                      padding-bottom: 0;
                    h1 {
            - square: false
              type: grid
              cards:
                - type: custom:mushroom-climate-card
                  entity: climate.living_space
                  hvac_modes:
                    - cool
                    - 'off'
                  show_temperature_control: true
                  collapsible_controls: false
                  hold_action:
                    action: more-info
                  secondary_info: none
                  tap_action:
                    action: more-info
                  layout: horizontal
              columns: 1
            - square: false
              type: grid
              cards:
                  entity: input_boolean.air_conditioning_suspended
                  entity: binary_sensor.air_conditioning_overflow_tank_full
                  entity: light.air_conditioning_tank_pump_switch
                  entity: binary_sensor.air_conditioning_tank_full
              columns: 2
        cards:
            card_mod:
              style:
                  div.header {
                    padding-bottom: 0;
                  h1 {
            card:
              title: Kitchen
              alignment: start
          - type: grid
            columns: 2
            square: false
            cards:
                entity: sensor.kitchen_refrigerator_temperature
                layout: horizontal
                primary_info: state
                secondary_info: name
                entity: sensor.kitchen_refrigerator_humidity
                layout: horizontal
                primary_info: state
                entity: sensor.kitchen_freezer_temperature
                layout: horizontal
                primary_info: state
                entity: sensor.kitchen_freezer_signal_strength
                layout: horizontal
                primary_info: state
          - type: conditional
            conditions:
              - entity: sensor.kitchen_cooking_temperature_probe_1_uncalibrated
            card:
              type: grid
              columns: 2
              square: false
              cards:
                - type: custom:mini-graph-card
                  entities:
                      show_line: true
                      smoothing: false
                  points_per_hour: 60
                  hours_to_show: 1
                  show:
                    icon: false
                    legend: false
                  entities:
                    - entity: sensor.kitchen_cooking_temperature_probe_2
                      show_line: true
                      smoothing: false
                  points_per_hour: 60
                  hours_to_show: 1
                  show:
                    icon: false
                    legend: false
                - type: entities
                  entities:
                    - entity: input_text.kitchen_cooking_temperature_probe_1_target
                      name: Target 1 (°C)
                - type: entities
                  entities:
                    - entity: input_text.kitchen_cooking_temperature_probe_2_target
                      name: Target 2 (°C)
                  entity: sensor.kitchen_cooking_temperature_probe_1_alert
                  primary: >
                    states("sensor.kitchen_cooking_temperature_probe_1_alert") |
                    capitalize }}
                  icon: >
                    {% if "above" in
                      or "below" in states("sensor.kitchen_cooking_temperature_probe_1_alert") %}
                    mdi:thermometer-alert {% else %} mdi:thermometer-check {%
                    endif %}
                  entity: sensor.kitchen_cooking_temperature_probe_2_alert
                  primary: >
                    states("sensor.kitchen_cooking_temperature_probe_2_alert") |
                    capitalize }}
                  icon: >
                    {% if "above" in
                      or "below" in states("sensor.kitchen_cooking_temperature_probe_2_alert") %}
                    endif %}
I have a lot of views (tabs). Which would require excessive scrolling on the view bar on the mobile device.
Also you can’t assign a default view for a device.
Thanks so much those are some great ideas.
