already wrote up an issue, , but maybe anyone here can help/check?
using a type: grid card to show conditional button cards, all squares (using aspect_ratio: 1/1) , it always shows the first (left) position as an empty placeholder without a card.
other than that, the grid is filled perfectly, and depending on the conditions for the individual cards, fills as should. Also adding new horizontal stacks on more than 4 cards works beautifully.
hope this is not caused by the conditional effect we see in other places too, always leaving space before the cards, even if they are not displayed.
Thanks for having a look!
other than that each card in that include has its own conditional of course.
Somehow there’s code in HA that creates an empty placeholder on the first conditional. there are other examples.
Using a horizontal stack with conditional cards does it too, although you have to look carefully. I did a post on that a longg while ago and it was never solved, or even looked at maybe…
