Hi there,
None of my Dashboard are working anymore after the upgrade to 2025.1.1.
Seems now to be an issue with the grid-layout I am using on all my dashboards, see below :
Any issue using this now ?? I have not seen anything saying it would break ?
Anyone can help ?
Many thanks !
MoridinTX
(MoridinTX)
January 8, 2025, 4:34pm
2
I am not having any issues with grid layout after the update to 2025.1.1.
thank you @MoridinTX
Do you have same code as above, because on some examples I see something different like :
type: custom:layout-card
layout_type: grid
layout_options:
But that is also not ok
It is ok … I figure out the HACS was disappeared after upgrade the 2025.1.1 …
I had to load a new version 2.0.2 and it is working back
Many Thanks !!
TheBigS
(The Big S)
January 13, 2025, 7:36pm
5
How did you install 2.0.2? I’m having the same issue and I don’t see an update available for HACS. I have 2.0.1 installed.
TheBigS
(The Big S)
January 13, 2025, 8:05pm
6
Nevermind. Fixed it, I think I was stuck on 2.0.1 because I originally installed HACS via Terminal, here is what I did to fix it:
Uninstall / Delete existing HACS integration (Devices->Integrations)
Go to addons, add custom add repository: GitHub - hacs/addons . Search for and install the HACS addon
Run the hacs addon. Then examine its logs, it will install updated hacs then exit.
Full restart home assistant
Go back to Devices->Integration and install HACS, now I have 2.0.2!
Go back to settings->updates and install updates to card-layout and fully-kiosk
Refresh dashboards, success!
