Minimalist-UI Custom:Button-Card , Grid layout
I am trying to create a minimalist dashboard and I am also new ti yaml.i would like to add a grid directly under the card person.how dop i force my grid to start vertically.Is there a way to permanently fix the starting position of the grid.
title: “Home”
path: “home”
cards:
  • type: “custom:button-card”
    template: “card_esh_welcome”
    triggers_update: “input_boolean.minimalist_dropdown”
    variables:
    ulm_card_esh_welcome_collapse: input_boolean.minimalist_dropdown
    ulm_weather: “weather.openweathermap”
    entity_1:
    nav: “bathroom”
    icon: “mdi:bathtub”
    color: “blue”
    entity_2:
    nav: “lights”
    icon: “mdi:lightbulb”
    color: “yellow”
    entity_3:
    nav: “security”
    icon: “mdi:shield”
    color: “green”
    entity_4:
    nav: “network”
    icon: “mdi:nas”
    color: “purple”
    entity_5:
    nav: “network”
    icon: “mdi:flask”
    color: “red”
  • type: horizontal-stack
    cards:
    • type: ‘custom:button-card’
      template: card_person
      variables:
      ulm_card_person_entity: person.jay
      ulm_card_person_use_entity_picture: true
Could we see a visual? Also:
If I understand your problem correctly, you could use this, which forces your grid to only have one column, placing all the card below eachother. This is practicly the same as vertical-stack, but then you could use the benefits from grid.
- type: grid
  columns: 1
  cards:
  - type: your cards
  - and so on
More info: Grid card - Home Assistant
Better would be if you use vertical-stack in combination with horizontal-stack, like so:
- type: vertical-stack
  cards:
  - type: your-card-full-width
  - type: horizontal-stack #could be 'type: grid' as well
    cards:
    - type: your cards next to eachother
More info: Vertical stack card - Home Assistant
As Mention above please “format code”
And as you are using Custom:Button-Card Template ( Most likely with your button-card-grid defined there, it would be most relevant you also showed this(formatted) ( beside a pic i.e how you’d expect it to look like )
Customizing - UI Lovelace Minimalist.
🌻 Lovelace UI • Minimalist.
PS: I changed Your Header, and Category, to reflect the Dashboard , Card and “issue” you are facing.
You also might be better of Searching in The Big Forum-Topic for this Dashboard “Lovelace UI” above, and post a question in this Topic/Project
The docs for this specific Dashboard you find in the first link above
thanks every i got it to work with everyone’s suggestion
