Grid without separation?
This code:
square: false
columns: 2
type: grid
cards:
  - type: entity
    entity: binary_sensor.connectivity_4
    state_color: true
  - type: entity
    entity: binary_sensor.home_assistant_website_update_available
    state_color: true
  - type: entity
    entity: sensor.hacs
    state_color: true
  - type: entity
    entity: sensor.potential_breaking_changes
    state_color: true
  - type: entity
    entity: binary_sensor.remote_ui
    state_color: true
  - type: entities
    entities: []
Show:
real
How would it be done to see it:
buscado
I have tried several cards and I did not find the way… so I kept the most similar, any suggestions? some mistake?
You might have a look at GitHub - custom-cards/stack-in-card: 🛠 group multiple cards into one card without the borders
I have this setup for my take on a climate card. It might be using the card-mod from Thomas Loven, which can be installed trough HACS.
type: custom:vertical-stack-in-card
cards:
  - type: markdown
    content: '# Bedroom'
    style: |
      ha-card {
        box-shadow: none;
        border: none;
        margin: 0;
      ha-markdown.no-header {
        box-shadow: none;
        padding: 0 0 0 16px;
        border: none;
        margin: 0;
  - type: custom:stack-in-card
    mode: horizontal
    cards:
      - type: markdown
        content: >-
          <ha-icon icon="mdi:thermometer"></ha-icon> Current {{
          state_attr('climate.bedroomthermometer','current_temperature') }} ºC
        style: |
          ha-card {
            box-shadow: none;
            border: none;
            margin: 0;
            box-shadow: none;
            border: none;
            margin: 0;
      - type: markdown
        content: >-
          <ha-icon icon="mdi:thermometer"></ha-icon> Target {{
          state_attr('climate.bedroomthermometer','temperature') }} ºC
        style: |
          ha-card {
            box-shadow: none;
            border: none;
            margin: 0;
            box-shadow: none;
            padding: 0 0 0 0;
            border: none;
            margin: 0;
  - type: entities
    entities:
      - type: custom:slider-entity-row
        entity: input_number.bedroom_set_temperature
        full_row: true
        hide_state: true
        min: 5
        max: 27
        step: 0.5
        style: |
          ha-card {
            box-shadow: none;
            border: none;
            margin: 0;
            box-shadow: none;
            padding: 0 0 0 0;
            border: none;
            margin: 0;
    mode: horizontal
    cards:
      - type: custom:button-card
        icon: mdi:calendar-sync
        entity: climate.bedroomthermostat
        show_name: false
        color: var(--primary-text-color)
        state:
          - value: auto
            color: green
          - value: heat
          - value: 'off'
        tap_action:
          action: call-service
          service: climate.set_hvac_mode
          service_data:
            entity_id: climate.bedroomthermostat
            hvac_mode: auto
        icon: mdi:hand-back-right
        show_name: false
        state:
          - value: auto
          - value: heat
            color: green
          - value: 'off'
        tap_action:
          service_data:
            hvac_mode: heat
        icon: mdi:briefcase
        entity: switch.bedroomvacation
        show_name: false
        state:
          - value: 'on'
            color: orange
          - value: 'off'
        tap_action:
          service: switch.toggle
          service_data:
            entity_id: switch.bedroomvacation
        styles:
          grid:
            - position: relative
          custom_fields:
            notification:
              - position: absolute
              - left: 47px
              - top: 41px
              - height: 25px
              - width: 25px
              - font-size: 12px
              - color: red
        custom_fields:
          notification: |
              if (states['climate.bedroomthermostat'].attributes.preset_mode == 'boost')
                return (states['counter.bedroom_boost_timer'].state)
        state:
          - value: 'on'
            color: red
            icon: mdi:radiator
          - value: 'off'
            icon: mdi:radiator
        tap_action:
          service: script.bedroom_boost_toogle
        entity: sensor.bedroom_thermostat_boost
        show_name: false
        show_icon: true
        show_state: false
  - type: conditional
    conditions:
      - entity: switch.bedroomvacation
        state: 'on'
    card:
      type: entities
      entities:
        - input_datetime.bedroom_vacation_date
    mode: horizontal
    cards:
      - type: markdown
        content: >
          {% if (state_attr('climate.bedroomthermostat','valve') != 4) %}
            <font color='red'>
          {% endif %} <center> <ha-icon icon="mdi:valve"></ha-icon> {{
          ((state_attr('climate.bedroomthermostat','level'))*100)|round }} %
          <center> {% if (state_attr('climate.bedroomthermostat','valve') != 4)
            </font>
          {% endif %}
      - type: markdown
        content: >
          <center> <ha-icon icon="mdi:water-percent"></ha-icon>{{
          state_attr('climate.bedroomthermometer','current_humidity') }} %
          </center>
      - type: markdown
        content: >
          <center> {% if (state_attr('climate.bedroomthermometer', 'battery') ==
          'High') %}
            <ha-icon icon="mdi:thermometer"></ha-icon><font color="green"><ha-icon icon="mdi:battery-high"></ha-icon></font>
          {% elif (state_attr('climate.bedroomthermometer', 'battery') == 'Low')
            <ha-icon icon="mdi:thermometer"></ha-icon><font color="yellow"><ha-icon icon="mdi:battery-low"></ha-icon></font>
          'Critical') %}
            <ha-icon icon="mdi:thermometer"></ha-icon><font color="red"><ha-icon icon="mdi:battery-outline"></ha-icon></font>
          {% else %}
            <ha-icon icon="mdi:thermometer"></ha-icon><font color="orange"><ha-icon icon="mdi:battery-unknown"></ha-icon></font>
          {% endif %} </center>
      - type: markdown
        content: >
          <center> {% if (state_attr('climate.bedroomthermostat', 'battery') ==
          'High') %}
            <ha-icon icon="mdi:thermostat"></ha-icon><font color="green"><ha-icon icon="mdi:battery-high"></ha-icon></font>
          {% elif (state_attr('climate.bedroomthermostat', 'battery') == 'Low')
            <ha-icon icon="mdi:thermostat"></ha-icon><font color="yellow"><ha-icon icon="mdi:battery-low"></ha-icon></font>
          'Critical') %}
            <ha-icon icon="mdi:thermostat"></ha-icon><font color="red"><ha-icon icon="mdi:battery-outline"></ha-icon></font>
          {% else %}
            <ha-icon icon="mdi:thermostat"></ha-icon><font color="orange"><ha-icon icon="mdi:battery-unknown"></ha-icon></font>
    mode: horizontal
    cards:
      - type: custom:layout-card
        layout_type: grid
        layout:
          grid-template-columns: 56px 30px
        cards:
          - type: markdown
            content: |-
              <center> {% if is_state('binary_sensor.bedroom_sensor_1', 'on') %}
                <font color="red"><ha-icon icon="mdi:window-open-variant"></ha-icon></font>
              {% elif is_state('binary_sensor.bedroom_sensor_1', 'off') %}
                <font color="green"><ha-icon icon="mdi:window-closed-variant"></ha-icon></font>
              {% else %}
                <font color="yellow"><ha-icon icon="mdi:sync"></ha-icon></font>
            style: |
              ha-card {
                box-shadow: none;
                border: none;
                margin: 0;
                box-shadow: none;
                padding: 0 0 0 26px;
                border: none;
                margin: 0;
          - type: markdown
            content: >-
              <center> {% if (state_attr('binary_sensor.bedroom_sensor_1',
              'battery') == 'High') %}
              {% elif (state_attr('binary_sensor.bedroom_sensor_1', 'battery')
              == 'Low') %}
              == 'Critical') %}
              {% else %}
                <font color="yellow"><ha-icon icon="mdi:battery-unknown"></ha-icon></font>
            style: |
              ha-card {
                box-shadow: none;
                border: none;
                margin: 0;
                box-shadow: none;
                padding: 0 0 0 0;
                border: none;
                margin: 0;
        layout_type: grid
        layout:
        cards:
          - type: markdown
            content: |-
              <center> {% if is_state('binary_sensor.bedroom_sensor_2', 'on') %}
              {% elif is_state('binary_sensor.bedroom_sensor_2', 'off') %}
              {% else %}
            style: |
              ha-card {
                box-shadow: none;
                border: none;
                margin: 0;
                box-shadow: none;
                border: none;
                margin: 0;
          - type: markdown
            content: >-
              <center> {% if (state_attr('binary_sensor.bedroom_sensor_2',
              {% elif (state_attr('binary_sensor.bedroom_sensor_2', 'battery')
              == 'Low') %}
              == 'Critical') %}
              {% else %}
            style: |
              ha-card {
                box-shadow: none;
                border: none;
                margin: 0;
                box-shadow: none;
                padding: 0 0 0 0;
                border: none;
                margin: 0;
        layout_type: grid
        layout:
        cards:
          - type: markdown
            content: |-
              <center> {% if is_state('binary_sensor.bedroom_sensor_3', 'on') %}
              {% elif is_state('binary_sensor.bedroom_sensor_3', 'off') %}
              {% else %}
            style: |
              ha-card {
                box-shadow: none;
                border: none;
                margin: 0;
                box-shadow: none;
                border: none;
                margin: 0;
          - type: markdown
            content: >-
              <center> {% if (state_attr('binary_sensor.bedroom_sensor_3',
              {% elif (state_attr('binary_sensor.bedroom_sensor_3', 'battery')
              == 'Low') %}
              == 'Critical') %}
              {% else %}
            style: |
              ha-card {
                box-shadow: none;
                border: none;
                margin: 0;
                box-shadow: none;
                padding: 0 0 0 0;
                border: none;
                margin: 0;
        layout_type: grid
        layout:
        cards:
          - type: markdown
            content: |-
              <center> {% if is_state('binary_sensor.bedroom_sensor_4', 'on') %}
              {% elif is_state('binary_sensor.bedroom_sensor_4', 'off') %}
              {% else %}
            style: |
              ha-card {
                box-shadow: none;
                border: none;
                margin: 0;
                box-shadow: none;
                border: none;
                margin: 0;
          - type: markdown
            content: >-
              <center> {% if (state_attr('binary_sensor.bedroom_sensor_4',
              {% elif (state_attr('binary_sensor.bedroom_sensor_4', 'battery')
              == 'Low') %}
              == 'Critical') %}
              {% else %}
            style: |
              ha-card {
                box-shadow: none;
                border: none;
                margin: 0;
                box-shadow: none;
                padding: 0 0 0 0;
                border: none;
                margin: 0;
I went with GitHub - ofekashery/vertical-stack-in-card: 📐 Home Assistant Card: Similar to vertical/horizontal-stack, but removes card borders to obtain this layout for my vacuum :
Screenshot - 06_02_2023 , 08_00_57
vacuum
cards:
  - type: custom:mushroom-vacuum-card
    entity: vacuum.vacuum
    fill_container: false
    icon_animation: true
    commands:
      - start_pause
      - return_home
    tap_action:
      action: navigate
      navigation_path: /lovelace/vacuum
    layout: horizontal
  - type: horizontal-stack
    cards:
        primary: Kitchen
        icon: mdi:robot-vacuum
        icon_color: |
          {% if is_state('vacuum.vacuum', 'cleaning') %}
            orange
          {% else %}
            blue
          {% endif %}
        secondary: ''
        entity: script.vacuum_kitchen_with_zone
        card_mod:
          style:
            mushroom-shape-icon$: |
              ha-icon {
                {{ '--icon-animation: rotation 8s linear infinite;' if is_state('vacuum.vacuum', 'cleaning') }}
              @keyframes rotation {
                0% {
                  transform: rotate(0deg);
                100% {
                  transform: rotate(360deg);
        primary: Kitchen + entry
        icon_color: |
            orange
          {% else %}
            blue
          {% endif %}
        secondary: ''
        entity: script.vacuum_kitchen_and_entryway_with_zone
        card_mod:
          style:
              ha-icon {
                0% {
                100% {
