Grill Buddy is your grilling companion, designed to simplify temperature monitoring during barbecues and cookouts. It seamlessly integrates with your Home Assistant enabled temperature sensors (probes) and supports various presets for proteins (such as beef, pork, and fish) and doneness levels (rare, medium, well-done and more). With Grill Buddy, you can set and monitor the following goals:
Target Temperature: Specify the desired temperature for your food.
Temperature Range: Monitor temperatures within specific value ranges.
Out-of-Range Alerts: Receive notifications when temperatures fall outside certain limits.
Threshold Alerts: Get notified when temperatures go below or above a specific value.
Once your cooking goal is achieved, Grill Buddy updates the status to “goal reached.” Additionally, it provides detailed information about your thermometer probe’s status based on the chosen goal. Plus, it even predicts when you’ll reach your target temperature, allowing you to plan ahead!
Remember to fire up the grill and enjoy your perfectly cooked meals!
Get started:
Find it in HACS (coming soon, waiting on PRs to be merged)
I have 2024.5.2 of Grill Buddy installed in HA Core 2024.5.4. When I select Grill Buddy in the sidebar I’m offered the option to add a probe, but the Source drop down is empty (just shows --select–).
I have four Inkbird probes in HA that I’d like to use. Should they be compatible with this integration?
And the source selector is in desperate need of a filter/search.
For me it seems to list all entities, it could probably be filtered down to sensors only.
It found my 6 probe inkbird.
It took a while to load the list of entities
It loads all sensors and input_numbers. You have just have very long sensor names that’s what causing the wide drop down. I can limit it of course but then you wouldn’t know what to pick.
The load time is because you have many sensors. I will try to find a way to make the UI wait on the load to finish.
I updated to the latest version in hope that I could finally see the sensors.
But this version seems to have removed my ability to even select a sensor.
