Grocy Add-On - no data through web interface
I have installed the Grocy AddOn on a Home Assistant OS device, but the access outside ingress doesn’t work: there is no connection with the database.
In Ingress, I can see and update my data:
In web interface, no data:
When accessing the web interface through reverse proxy, then the data is displayed but cannot be edited…
The API does seem to work.
Any idea how to solve this?
I have exactly the same issue. Also if I want to add stock it won’t save it. I can add products, but not stock. I looks like there might be something wrong with the DB.
Same issue on my side too. Find a solution yet?
