Grocy possible with home assistant container?
Hello together.
I’m new with Home Assistant. I have installed the HASS Container. I just stumbled over Grocy, But the only installation method I found is via “Supervisor”, which is not available with FASS container. Is there another way to install it?
Best regards,
Do you mean that you have installed Home assistant in docker? You can install Grocy in docker as well.
Thank you Isabella.
I should have researched this first before I made this post. Sorry for that. :confused:
